I have been searching the threads and cannot find discussion on wakeboarding speed... if you want to point me to the threads that would be great. I have been experimenting with speeds/rope length on my 22Ve and am having trouble finding my sweet spot in the wake. What speeds/rope length have you found works best? Thanks in advance.
Wakeboarding Speed?
Originally posted by kknobl58185 View Posti like to use 75 at like 23.5 ish... have some people who ride with us use 80 to 85 at 25 to 27... if your at 60ft i would start at something like 20 21 or at 70 do 22- 23 ... i would say just play around try different things until you find the spot you like and a speed you like..
Throw your rope out at any length behind the boat. Get the boat up to speed and where the rope handle rests in the wake just before the wash is where your sweet spot is. Then adjust a bit either way to find where you are comfortable.2016 Tige Z3, 2014 Tige Z3
You should be able to clean the wake up with the taps. Higher the taps the closer the sweet spot gets to the boat. The slower you go the closer it gets as well. I suggest find the speed you are comfortable with and adjust from there. Like Loadelectronics said, just before the white wash is the sweet spot.
