Every time we go surfing lately after a few sets when coming back to a downed rider at or just above idle my 2004 22V with 350 mercruiser will die. We can always fire right back up but it is certainly annoying and a bit worrisome. We are not running that much weight, just a 400 in the port side, a 250 under the port seats and a 500 in the belly plus a few peeps. Any ideas? It used to seem like it would happen after hours of surfing, now it is more like 30 minutes. I had my local dealer look at it last year and they could not find anything. This season I got the impeller changed at the annual service. Any suggestions as always would be greatly appreciated!
motor shutting off when idleing between surf sets
GuestTags: None
Guest
No it is not alarming or running hot. I need to look closer at the exact temp next time but it is right at the temp it always runs at. I want to sat like 175?
Sounds like either a vacuum leak or a sticking IAC (Idle Air Control) motor. They are easy to remove and clean with a spray can of carb cleaner. May not hurt to clean the spark arrestor and throttle plates as well.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Guest
Thanks. Good stuff to check out this weekend, I will find a manual to find all these suspect parts and see what I can find.
Originally posted by AustinSouthSide View PostThanks. Good stuff to check out this weekend, I will find a manual to find all these suspect parts and see what I can find.
On second though, read this thread: IACLast edited by Moki; 06-08-2010, 04:31 AM.
Guest
That does sound like the IAC. That will be the first thing I look at on Saturday before I hit the lake. Thanks again Gentleman for the great advice!
I'm in the same temps as you, AustinSouthSide. I've found that I need to run my blower when temps are real hot because I have trouble restarting after I turn the motor off following a run. It could be that you're not getting enough air into your engine compartment. I'd also try cleaning the flame arrestor as Chpthril suggests.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
