Heat exchanger leak at bottom
    First time out today, My 2018 R21 is spraying water from bottom of heat exchanger. Throwing a check engine code on dash. Is there a way to change exchanger cap on bottom where water is shooting out. I pulled blue plug in December but I think it was too late. I was recovering from damage to my home from Helene and forgot. Indmar raptor 6.2 Liter. Has anyone done this before and any instructions or tips on best way to access and change bottom cap?
    There is only one bolt in the center (14mm I believe, same as top) that holds the cap. Due to this design the outer edges bend out creating a leak. You can take it off and straighten it. Temporary solution till you get a new cap/gasket kit.
      Just pulled it off. Warped/ bent pretty good. Thanks for reply. They don’t make them easy to get to.
