Restoring a '08 22ve
Got the sound system rebuild finished. I ended up going with a mix of Polk 6.5" speakers for the hull speakers and Skar 6.5" speakers for the tower. All of the original speaker cones were dead, and the tower buckets (bullets?) were badly oxidized/sunburned.
I wetsanded the buckets with 600 and 800 grit, then painted them with plastic compatible Krylon paint. The paint's not perfect, but it'll do, for now. I ended up using a wire brush on a bench grinder to clean up the metal brackets, then painted them with krinkle finish gray.
<to be continued>Last edited by Vettedrmr; 02-13-2025, 04:07 AM.
I've ended up not reusing anything other than wiring from the original system. Based on a lot of advice from this forum, I ended up finding a good deal on a refurbed Wetsounds MC-1 headunit with two remotes.
The original amp system had two Kicker amps (700.5 and 350.4) that were apparently non-marine rated. I replaced those two with a Kicker KMA 600.6, intending to replace the sub with a powered sub. However, I found that the existing sub reinforced the bass suitably for what I want (remember that I don't intend to blast my neighbors a half-mile away).
This is what it looked like after I did a fair amount of tidying wiring etc. up, but before I replaced the two amps:
And after I got the new amp installed:
Obviously I won't get to really test it until we get back out on the water, but in the shop everything sounds great.
Next up, more hull compounding work.
Y'all have a good one,
Mike
Next up was to get the transom emblem removed, the gelcoat compounded, the new emblem (thanks to Domed Numbers) applied, and the whole thing waxed. Domed Numbers didn't have the right size Tige emblem (Tige had zero, zip, nada), so they had me dimension the "box" the emblem was in, and they DESIGNED one for me. It's actually in their catalog now if anyone wants one.
Here's the old emblem.,
the fading of the gelcoat after the old emblem was removed...
and the new emblem after the gelcoat was compounded.
Next up is getting the gelcoat on the swim platform cleaned up and the platform re-installed. I've ditched the old rusted pins and will be using stainless bolts and nylock nuts.
Mike
