where are the wires and possibly fuses for the ballasts? I have an intermittent issue with my port bow pump not draining and its giving open current error on the PDM diagnostics. If i fiddle with some wires under the dash it will work again but not sure what's going on under there.
Ballast drain open circuit error, wont drain
An intermittent issue will rule out a fuse. Could be a poor splice or loose connector pin back near the pump.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I tightened that wire and it's still throwing PDM open circuit for both bow drains. But they both make noise like they're working. I had another similar problem last week with a stern ballast not filling, but the pump was making noise and running. This one did not make the PDM show open circuit. I'm kinda at a loss here idk what's going on. So far every time this happens they eventually just start working again but I'm worried I'm going to get stuck with full bags one time.
Those pumps have a about a 24" brown and black wires so there is a splice or connector somewhere. FYI, those pumps in the bilge pictured are the fill pumps, not the drain pumps.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostThose pumps have a about a 24" brown and black wires so there is a splice or connector somewhere. FYI, those pumps in the bilge pictured are the fill pumps, not the drain pumps.
