First time out on our new to us boat, 2011 RZ4, and couldn’t get the TAPS to set and stay where we wanted it. It eventually tripped the reset and so I quit messing with it on the water. Fast forward to the next day in my driveway, I hit the reset, and tried it. I can hear the pump running when I hit the rocker switch but the plate doesn’t move. Took the plate loose from actuator and plate moves freely. Removed the lexan housing from pump and at some point the solenoid was hot enough to melt part of the housing. Gauge currently reads it at 8. Is it possible the pump is weak? Bennett v351 with single solenoid. Any help is appreciated. Thanks!
