I am looking to replace the carpet in my 2005 24V with a Sea Deck like material. I am hoping someone out there has made a template of the floor area that has been converted to a CAD file of any type (dwg, dxf file) and willing to share the file. I know the floor under the carpet is unfinished and will need leveling. I would also appreciate any guidance for the floor finishing process.
Sea Deck or Similar Fitment Question
Gatorstep, seadeck, or ultre deck should already have the file on hand. I sense you are looking to do it yourself tho.. might end up having to trace it out manually.
Give this a read if you haven’t already. Lots of helpful methods
https://www.tigeowners.com/forum/gen...-the-ground-up
The reason they dont have a template on the website is likely because of the floors needing to be finished and sizes will vary. I would reach out to gatorstep directly.
Here is a 24v refinished with gatorstep https://www.wakegarage.com/projects-...-refresh-r275/
