Is this odd?
    Is this odd?
    Reading posts on PPS (Pedal Position Sensor), my 2005 Switch Ci has similar issues running great, then rough and on 4 cylinders. I removed my throttle thinking to check the PPS! Looks as though I dont have one on the throttle like in earlier posts I was reading with a pictorial on R&R the PPS.?
    Can anyone comment on this?
    An 05 would likely have a cable driven throttle v's an 06 with DBW. So no PPS on the throttle, just a TPS on the throttle body.
      Throttle by wire started in 2006. Yours is a cable push/pull.
