2022 Z3 Speedo not working
    Morning all,
    This morning I noticed my time was off.. showed 6pm and stayed at 6pm. Made sure time zone is set properly, then speedo stopped working. Checked satellites and shows 0 connected. GPS puck is not covered… was wondering if there is a fuse I should check for? And if so, where would it be located?
    Did you look and see if the puck had come unplugged?
      Weirdest thing… so one thing I noticed before these problem was the battery switch was still in the one position from the day before. Boated for a couple hours, and shut the battery off for about an hour, when I came back, switch battery to on and GPS connected like usual. I’m thinking it might have timed out from not turning the battery off the day before.
