I've got a 1999 2100v that I probably put about 50 hours on a year. How often should I change the impeller? Our local marina mechanic suggests changing it every other year, but is that overkill? And I think I had heard at one point that someone makes a 'run dry' impeller that will last longer and could even be run dry for short periods of time, though I don't need to do that ever. Any recommendations for how often to replace it and what type to buy?
How often should I change my impeller?
Here's the run-dry for that pump. Run it and never change it again.
https://defender.com/en_us/globe-200...ler-01-12-1811Fixing everyone elses boat just so I can use mine...
We installed one in our 99' and sold it 10 years later with no issues. I replace all of our customers' with these where applicable and put one in my Raptor 400 last year. But basically lifetime. I recommend installing a water pressure gauge for everyone but that's up to you. As for the Z409, you'll have to look up the impeller number on their website.Fixing everyone elses boat just so I can use mine...
There are several different manufacturers available and several different mounting options but here's the gauge we like the best... https://www.autometer.com/2-1-16-wat...B&gclsrc=aw.dsFixing everyone elses boat just so I can use mine...
