Hi,
I had an issue today where we were losing power between 3500 and 4000 RPM but not consistently. I have a 2005 22v Marine Power. Found another thread discussing the fuel pump. I found a wire and plugged that in that was just below the fuel filter. However, I found an a bolt with a pointed end and 3 nuts in the bottom of the engine bay. I purchased the boat last year so its possible but unlikely they have been down there for long. I looked around and couldn't find anything obvious. Anyone have ideas of where I should look? I uploaded a photo of them. The washer was a hose that I fixed. The ball bearing was likely from my previous project (water pump). Also on the port side of the engine there is a cap in the center of the block. There was also a hose that looked like at one time it connected there. I uploaded pictures of both locations.
Any ideas?
Any ideas?
. Most of the time it's unrelated to anything important unless you recently dropped it there.
