White rub rail marks
    I have white rub rails on the guides on my lift. They do not scratch the gelcoat of coarse but they leave a white steak on my black hull. Using vinegar get a lot of it off, but some just will not come off. Does anybody know anything that will remove the remaining streaks?
    If they are like the lift streaks I get, they seem to be strands of some sort of rubber or vinyl or ???. Mine peel off lengthwise, rather than scrub off.
      Acetone on a rag will make it come right off but be mindful so will all your wax. Could also try a magic eraser.
        I use acetone as well for dock rash
          As mentioned above acetone for the win
          surf till u die.
            Kent Acrysol is a mild solvent.
              Great advice, the acetone worked great. Thanks.
