22i wiring diagrams?
    Does anyone have a wiring diagram for 2007 22i? I want to clean up the wiring and also need to know where the fuel sending unit wires run, and where to ground it.
    Anyone have the wiring from ecm back to battery? I have these wires disconnected and pretty sure its the power to the ecm harness
      Those look like factory amp wires. ECM does not have wire directly to the battery.
        Thank you, and you're right I was trying to trace the harness that plugs into the ecm. For some reason I do not think Im getting any power to the ecm. Had a sketchy audio guy work on the boat and im really hoping he didnt hook the batteries up backwards and fry the ecm or something.
          ECM most times gets the power from the TACH signal wire.
