Just purchased my first V drive boat. 2014 Z1. So I am really green and would really appreciate any and all help, I am guessing a vibration at mid rpms is a problem? (feel the vibration in the floor). No vibration at lower or higher rpms. Just while throttling up. Prop does not appear to be bent or damaged to the eye. Thanks!
Vibration Z1
Make sure your propeller isn’t loose. If it is you may need to lap the taper fit before tightening it as the propeller tapered bore will wear if the prop is loose. If it is bad enough you may need to have it professionally repaired or may even need to replace it.
