Anyone know if/where there is an accessory “pig tail” to pull power from on the newer models that is powered with the ignition. Low amp draw.
Switched accessory power on newer models
What would you need to power with the ign in the RUN position?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Purple wire anywhere in the boat is the hack way to do it. Otherwise if you have a new Z3 there should be a big ol bus bar that's fused near the starter. Just put a wire on one of the studs and run it uo the Starboard gunnel to the dash. If you wire it to that bus bar the Garmin will have power anytime master switch is on
You fishing on a wake/surf boat??
