Does anyone know what kind of material this is that is used as the backing material inside the carpet trim? Is it pvc or starboard or something else like that? It appears to be some sort of plastic material and it measures 1/8" thick by 1.5" wide. I need to get 20' of it. Not sure it's relevant, but this is on a 2004 Tige 20v Switch wakeboard boat.
Trim Backing Material
Its HDPE. How long is the longest piece you need? If you find a local'ish source, you get them to cut you a piece long and wide enough to then cut your individual 1.5" wide x ??? pieces.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
- 1 like
I work with it all the time. 1/8th x 1-1/2 is going to be very flexible. For sharp bends, you can heat and mold it prior to applying the covering.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
- 2 likes
