I'm planning on installing gatorstep in my 08 RZ2. I'm looking for solutions to cover this gap. The factory had carpet wrapped over nylon strips. Any suggestions? My best thought is to wrap it with gatorstep.
Wall to Floor Gap Trim
Anyway you can reuse those same strips? Another option would be to buy some 1/4' HDPE and cut some new strips and bevel the top edge. From there, you could still put the GatorStep over top.
How are you dealing with the floor heights and the access panel to the bilge? I've seen some people completely make a new bracket and hatch cover in the past.
I can reuse the strips and wrap them with eva.
I plan to sand down any high spots, fill any holes with epoxy, and router the access panel flush into the floor. I'm going to run gatorstep into the hatch seams like the carpet was, that way I don't have to build it out with epoxy and get everything perfect.
Here is what I did for the floor panel. I'll run a sheet of fiberglass over it, then screw the panel down until it's flush.
As for the wall trim, I'm thinking of buying some of this. I suppose gatorstep could cut me some too.
https://www.amazon.com/CHURERSHINING...8&sr=8-30&th=1Attached Files
Originally posted by kdammen View PostI'll start a build thread shortly. The hatch came out nice and level. I just sent in my templates. They said they are out 3-6 weeks currently for production. Hopefully I can get this done by early May.
Here is what I ended up doing. I bought some cheap eva strips on amazon: https://www.amazon.com/dp/B07PM66SND/
I was able to stick them directly on the walls. It covers the 3/4" gap with enough strength I didn't feel I needed the plastic backer. Made it super clean looking and easy.
