Winterizing…help???
    Winterizing…help???
    2013 z3. 343 PMC
    I want to make sure I didn’t miss anything as my set up looks different than the manual????
    specifically #4 in the illustration. The first picture is me pointing at the raw water strainer. The second picture is me pointing where the water leaving the strainer goes in. I do not see anything like the cyclones run the picture…
    AND!!!! What is letter A and B ????? There is no mention of them in the manual illustration????
    A and B are the heater lines. One needs to be removed and compressed air blown thru the lines while you have the block plugs out...that's IF your boat has a heater.
    I'm nit getting you first question about the strainer and "cyclone"
      Supposed to be cylinder. On the manual illustration. In mine the water goes from the strainer to the v-drive.
        Do you have a further back picture, one that shows more?
          No, I will get one….
