Avx
    Avx
    Should I be able to raise and lower the AVX on the trailer? I went into the surf system in the touch screen and ran the AVX from 0 to 10 and nothing happens. Between buying my rz2 and bringing it home I have seen it act different positions. But now id doesn't seem to be working unless I'm doing something wrong. I just wanted to run it up and down to see how much travel it had and also see if it works. Any tips? Thanks.
    Sent from my LM-V600 using Tapatalk
    You have to get it to move in the dealer menu. There's a demo mode there. It doesn't deploy until you get up to speed via the regular TT menu
    DO NOT switch to surf mode in the menu and do a demo.
      Perfect in got it to go into demo mode. The first time I tried it wasnt doing any thing. Thank you!
        Is 9191 the only dealer code or is there more for other menus?
          9191 is the only one I know for Tige. I know some others for Skiers Choice and Fineline.
            In the dealer menu you need to choose = to surf speed before it will move.
