Sorry if this isn’t in the right forum area, and mods can move if needed.
I have a 2002 22i with the originals TAPS system and has a question about the setting of the taps plate when surfing. I run about 800 lbs of ballast in the rear lockers plus whatever people I have on board, plus I’ll be trying a 375 lb bag up front this weekend to see if it helps the boat plane out a little more to lengthen the wave.
My question is about the TAPS plate in general. Does the wakeboard setting move the plate up towards the swim platform or down? And I always forget to adjust it when we surf, so wanted to get some input from you guys? What setting should it be in when surfing? Thanks
