I surveyed a 34' Sea Ray last week, twin 8.1 Mercruiser v-drives and at haul out discovered the props were not fully seated on their shafts. The same afternoon I received an insurance claim where the shaft had snapped mid taper and my investigation revealed it was from the prop not seating on the shaft correctly. If the prop is not installed correctly, too loose or not lapped to the shaft, it will do something called cyclical loading and eventually break the shaft at the woodruff key end after a crack developes. This means a new shaft and a new prop plus whatever damages were incurred when the prop hits the hull or rudder.
Flash forward to yesterday and we're out on Lake Mohave taking a swim break with Hank and I figure "Hey, lets check the prop!" and find it's loose on the shaft! I grab my trusty tool kit and tighten the nut to ludicrous level and run the rest of the day. However, it was eating at me enough to post this for the forum because my recommendation to the sea ray buyers was replace the shafts immediately and now I'm going to do the same on our Tige. Running the weight we do, the propeller speed, the fact we have 400 hours and it was cyclically loading both the keyway and the shaft taper for an unknown number of those hours, most likely since the prop was installed incorrectly before we purchased it, but I'm not taking a chance.
To help others (including dealers) know how to correctly install a propeller, please read below. I've also included a photo of the broken shaft which has a diameter of 1.5" and an aquamet 19 rating.
The following is an excerpt from "Propeller Installation" written by Steve D'Antonio and a link to his article. Everything in it is correct EXCEPT when he commits the cardinal sin and says to USE A FEW DROPS OF LUBRICANT OVER THE KEYWAY AND TAPER. NEVER EVER USE ANY LUBRICANT TO INSTALL A PROPELLER ON ITS TAPER!!!! EVER!!! ALWAYS INSTALL PROPELLERS DRY!!!
The first time a propeller is mated up with a shaft, whether both or either are new, they should be lapped to ensure a proper fit. Lapping is essentially custom fitting a prop to a shaft using an abrasive compound that’s designed for installation of intake and exhaust valves in engine cylinder heads. The process involves applying machinists dye or, “Prussian blue”, to the shaft taper, over which the lapping compound is applied; the latter has the consistency of wet sand. The propeller is then placed onto the shaft taper and rotated by hand 180° in either direction a dozen times or so. Doing so grinds away some of the material in the prop bore, establishing a custom fit. The prop is then removed and the lapping compound washed off. The dye that remains tells the installer if he or she has completed the lapping process, roughly 85-90% of the shaft taper should be dye-free or exposing the silver shaft material beneath. If this level of fit has not been achieved, then the process must be repeated until the 85-90% engagement is achieved. Once the lapping is complete all of the lapping compound should be thoroughly washed from the taper and propeller bore (it’s water soluble).
https://stevedmarineconsulting.com/p...-installation/
