Truck is a International CXT. Is the worlds biggest pick up truck.
jake, you are right on. Sea Dek is making a custom one piece right now with the WS logo cut out of it. Should have it done pretty soon.
I am going to take some better shots of the system soon. Had a photo freind on the lake one day do the water shots but that was before the system was in. Same thing with the shots at the factory. that was with the Tige factory Wet Sounds system. As you can see it had 60's on the tower then.
Hydrotunes does some amazing work. It really is a work of art. But cool thing is. Truly is functional. No loss of space in back at all. And storage trays on top of the sub boxes.
So still plenty of room for the monster surf ballast system we run.
i'll get some of the batts and the wire. the XS Power batts are actually pretty hidden. they are 3 on each side built up under the area between the back lockers and side seats. So perfect weight dist and no loss of useable space. So if you open up the back lockers, you see nothing and if you open up the seats, you see nothing. You have to stick your head up under to find them.
This way I can put my lead pop bags and 750 pound sack in the rear locker and more pop bags under the port side seat for surfing.
