Originally posted by jmoore15
View Post
575 Raptor Fuel Consumption
Originally posted by jmoore15 View PostJust spoke with my dealer. They ran diagnostics on mine it was burning 20gph at 4200rpms while surfing! Swapped out the ecm and said that seemed to fix the problem. Was also able to get it to plane out with ballast after the swap. Can’t wait to get it out and see.
Interesting, never heard of ECM causing issues. Now you have me wondering on my boat. 2020 22RZX with the 400(2:1) and I cannot get on plane full ballast. I need to be about 30% in the rear to plane with 100% up front. It's really weird because I have been in a 2017 RZX2 without the 2:1 and it could do 80% in the rears. I've got the acme 2693 prop and at about 800 elevation.
ECM should have been able to be flashed with a .cal file. Curious how thehtechs condemned this one. Pulled an ECM off a known good SC boat(hard to believe with current inventory levels)??? Indmar sent them one??
Either way....1 and 1 aren't making 2 in my head on this one
Originally posted by jmoore15 View PostGot the boat out this evening after replacing the ecm. Boat is light years better. I am able to get the boat on plane even with full ballast. Running about 400 rpms lower and much quieter at surf speed. Not sure about gph yet since I didn’t haven’t out that long.
Originally posted by SONIC View Post
You obviously have more experience with it than most anyone else, can the 575 really not plane out with full ballast?
