Purchased my brand new used 2006 Tige 22ve in Feb. I love it. Now trying to dig into it a little deeper and configure it to surf. The ballast system I have is what the factory installed. Four hard tanks (two rear and two under the consoles). I've done the math based on the size of the tanks, and I know the tanks aren't all square, but can someone tell me what the factory tanks (when filled) weigh?
My math gave me an approximation of 600lbs;
Two 200lb tanks in rear and two 100 lb tanks in front.
I know there's a few guys on here that will know this info...as well as what I need to do to make my boat a better surf machine...I'm all ears, however, not interested in pulling out the current plumbing this season (maybe next). I know I'll sacrifice time to fill with the older pumps, but I don't care...it's time on the water.
Also, can someone settle a debate for me; when the ignition key is rotated to the left...does the engine hour meter still run? (I don't think it does...but a pal of mine thinks so).
Thanks for any help!
