sharing a couple of mods to '18 R23.
first, changed out the factory charger plug with a NOCO because the old one from tige always pushed through so thought it was, plugged in and charging but was not! actually ended up losing a battery. was an easy install just had to widen the existing cutout in rear bulkhead.
second, replaced back seat with an hdpe step-down with eva foam to match the gatorstep. made it so i can easily swap back to vinyl seat. was pretty straightforward. wanted to do this because we're always stepping down there in and out of boat and seems it's where vinyl seams always tear.
