Safely in Her Summer Home...
    Originally posted by Joeprunc View Post
    Looks nice Guapo. One questions I've always had was how do you get your boat to center on a lift like that properly? The reason I'm asking is I'll be having mine on a lift this weekend at the Delta house we rented.
    I've only put iy on once so I'm not quite sure. What you see in the pic is how it lined up by itself. I was concerned as I've seen other boats at the marina on a bit tilted. I would assume it has to do with how level the boat is setting as it is lifted up.
      We us a very similar lift it just floats up under the boat and starts a gradual lift so the boat settles in perfect. Super easy setup.
      I don't have the rubber grip on my boards are they just silicone glued to the boards?
        They are coming off this week. It's a used lift and the lift guy was supposed to have the bunks recarpeted before I brought the boat down...he didn't get around to it. They will be off this week. Theses are simply screwed down (recessed heads). I think the idea is that they don't hold water against your boat while in the lift thus reducing the chance of blistering...
