Originally posted by UNSTUCK
View Post
What’s the next big thing?
Originally posted by D&P Powell View Post
It may be closer to reality in 30 years, but when I am 82, I don't think marina charging stations will be a priority for me. In the meantime, I will keep laughing at the WAY overpriced Nautique with 2-3 hours of use before needing a charge. I am all for positive change, but I am also grounded in reality.
The electric motor is usually smaller, but based on loading I would think it would take the place of the transmission and still use a v-drive. The electric car I'm building right now uses 5 Tesla batteries that are about 22x14x3 inches. As I recall they weigh about 50 each. Tesla uses 16 of these in at least some of their cars to get the 300 mile range. I'm planning on about 100 with my 5 batteries. I'm not sure of the dimensions of a 60 gallon gas tank, but it holds only 360 pounds of fuel. The weight of the batteries would need to go over the trailer axles. I do like the idea of adding "lead" to them. Throw in another battery and plumb it with cable instead of hose. Just imagine the storage space with the engine compartment wide open.
Patent idea? Put the batteries on a sliding rail system and can move batteries fwd / aft or side to side......
Think about it? You could easily have 300lbs that could be moved around to help optimize pitch/roll for surfing or wakeboarding. Could even move the weight during side to side transfers...
