Adding shower attachment to 2017 RZX3
    Hey, I am looking to add the shower attachment to my RZX3 but I can't seem to find anywhere to order the factory one that you can get as an option.
    Anyone have any idea where to get this?
    Thanks
    You might have a look at bakesonline.com
      It's not a factory option as Indmar said they didn't want raw water being removed from the cooling loop. Can it be done sure?? Would I risk adding one to an engine that's still under warranty?? Not me.
      If you look at the option on the Tige website it has a note saying (Lake Temp.) The factory shower option isn't heated.
        Thanks freeheel4life and USWaker . I don't mind that it's not heated. It just needs to be a separate water tank. It's only for the winter when my boat will be in Florida. When we come out of the water we can rinse off not to bring al the salt in the boat and seats.
        I'll check those websites.
        Thanks,
          I don't think what you're looking for is offered unless you do something custom. The traditional shower offering runs of the engine water so it will just be pulling in saltwater. You would need to add in some sort of a tank. This is probably your best option. https://rinsekit.com/products/rinsek...e-booster-pump
            VinceRZX3 thanks for the clarification. You will definitely need a standalone tank for your needs then. Bonus is that it's free ballast lol.
            Find a tank that's suitable and then all you need is a 12v water pump and some hose and fittings.
            If it was me I'd just use a ballast bag that sat midship or in the rear locker and fill it before each outing...
