2013 Z1
    2013 Z1
    Battery swap getting ready for this season and Tige Touch is now a blue screen. any ideas before i get raped by a dealer?
    Did you replace both batteries? yes they're new, but what the voltage of each battery?
      replaced 4 total
      20 amp hour rate: 92
      Battery electrolyte composition: glass mat
      Battery purpose: starting/deep cycle
      BCI group size: 27M
      MCA at 32 degrees F: 900
      CCA at 0 degrees F: 580
      Freight class: 65
      Polarity: DT
      Reserve capacity: 175
      Terminal type: stud and post
      Volts: 12
        Did you put a meter on the batteries to test their static/at-rest voltage level?
          Solved the issue.
          John @ Tige replied to an email and instructed to unplug video cable coming from Medallion. flip main breaker. plug cable back in. all works as should again.
            This website is amazing, if you can’t figure it out, go check Tige owners. I’ll give this a try to fix my blue screen. Thanks for sharing
