My dealer hasn't seen anything like this before.
Any help interpreting these values? Some seem to be crazy readings.
Trying to chase down why the Diacom Marine system can't communicate with the boat to read codes. 2012 RZR, PCM 343.
Could it be a bad wiring harness? Which would help explain the rest of the small electrical gremlins. (intermittent loss of power while idling or surfing - almost like shutting the boat off) House voltage saying 18.6v (1 battery or 4 hooked up, doesn't change. updating didn't help)
Also boat won't start (just cranks over) until the throttle body/actuator cycles itself.
Red triangle lights up and beeps upon start up as well.
Waiting on PCM and Tige to send over schematics, ohm specs and stuff.
Picture is while the boat is idling with Fake-a-lake for about a minute
