2001 2100V Evolution Cover
    I emailed Cory and he said he had a pattern for the 1999 21V (or 2100V) but wasn't sure if this is the same as my 2001. Can someone confirm that this will work? I'm 99% sure they're the same given that the Westland Exact Fit cover lists 1999-2002 for their models. I just wasn't sure if there were any subtle differences. Note that I did install an aftermarket tower but I re-used the front mounting holes and the rears only shifted about 2" forward. I would assume he can make a slight modification for this but even if not, it'll probably work fine.
    Should be just fine either way. I replaced that same Metcrap factory tower and my rear mounts moved to the side instead of the top. I went with the stock Westland and it works just fine with no alterations.
