So I’m overly cautious about my drain plugs and the T handle style that you access under the trash can in the center of the of the boat that sits just in front of the transmission is seized up. The brass t handle is bending when I try to back out the plug. Any ideas as to how to get it out? Here’s a pic of the style of plug I’m referring to. I can’t get a wrench on it because the the handle and a pair of channel locks can’t get down low enough on the nut at the base because of the plug is slightly inset into the hull.
