Any suggestions on ballast bags for the V Drive side engine compartment on 2006 24VE. Looked at Fly HIGH and Launch Pad models. Dimensions of bags do not seem to fit well with 24VE. To me it seems they will be under filled due to requirement of fitting under the side seats. Do not necessarily want to go to the Enzo bag.
Ballast for 24VE
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Originally posted by Dan Carlson View PostAny suggestions on ballast bags for the V Drive side engine compartment on 2006 24VE. Looked at Fly HIGH and Launch Pad models. Dimensions of bags do not seem to fit well with 24VE. To me it seems they will be under filled due to requirement of fitting under the side seats. Do not necessarily want to go to the Enzo bag.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
If you want the best bang for the buck, the enzo is it for the 24ft Tiges. It's actually larger then the storage/under-seat area, so it fills every nook and cranny. In that boat, it holds about 1300 lbs per side for surfing.
Shoot me a PM (private message) if I can help you further with pricing on any of the Fly High sacs, pumps and fittings, as well as custom sacs.
MikeMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I have the 22ve which has less room, but I have the fly high 750 on each side, definitely doesn't fill up all the way. I have my boat weighted perfectly for my liking though: 750 in each locker, 400 on the floor against back seats, 400 in the walkway, 1000 triangle in the bow, and the two hard tanks on port and strbd which are about 100-150 each (my best guess). I run taps at 2-3 at 23.5 mph 75 ft rope
