Good luck. I highly doubt you’ll find one. They certainly don’t make them any more. You can try contacting Tige directly. Maybe they have one on a forgotten shelf in the back. Your best bet would be making a new one out of the old one.
I would reach out to @seastonemarine on IG. They rebuild panels for lots of salt boats/center consoles. This would be a new one for them but they are probably the only ones uo to it
That looks fantastic! How did you set the curvature of the main panel? Did it just cold bend, or do you use a heat gun or something? If heat, did you "trial and error" it? Or...
