Blisters
    Blisters
    I have a patch of blisters on the bottom of the hull approximately below the drivers windshield. Area is about 1 sqft. I have an 08 RZ2.
    Has anyone had blisters with 07-08 boats? Is this covered the hull warranty?
    That sucks man. At least it's on the bottom and not on the sides. Unfortunately blistering is not covered under warranty
      Do you keep it in the water for extended periods of time? Like a dock at your house?
        UNSTUCK i have it on a hydraulic lift but when I came to take the boat out for the winter the lift lost pressure and boat was sitting in the water. No idea how long. Could have been 4 to 1 weeks
          Is the blister line where your lift bunks sit? If you’re somewhere humid where things don’t dry the constant moisture can cause the blistering.
            bsreid interesting thought. Although the boat is stored on a lift the blisters might actually be right where the bunks sit. Although the bunks are a composite not carpet do not sure how moisture would stay unless it all occurred while the lift lost pressure. The lift is a front mount so the front area of the bunks could be in the water but still supporting the front 1/3rd of the boat.
