i have a black tige and the lower half of the back is not as shiny as the rest of the boat any ideas what to shine it up with
paint
3M Finess and a variable speed polisher, then marine polish, then wax. Get a course and fine polish pad and then finish with a wool pad and wax.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by jwanck11 View PostHow important is it to get a "good" polisher? They sell a rather cheap version at a local shop for 30 which is not too bad. Is it also important to get one that is random orbiting?
I used Meguiars MEG-M4916 OXIDATION REMOVER and elbow grease on mine...
I used Meguiars MEG-M4916 OXIDATION REMOVER and elbow grease on mine...You've got polishers and buffers. Polishers need to be variable speed so you dont "burn" the gel-coat or clear coat (on a car) and are for the first couple of restoration steps. They are best used with a course then fine eggshell pad and going from a rough to fine compound. Buffers typically have a fixed but medium RPM, and are often orbital. They are best for waxing stage and used with a wool covered pad.
So, for the restoration of a dull boat or car, one will need a polisher. For routine waxing of a good surface, then an orbital buffer is the ticketMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
