Material: high virgin raw material with submicron and average grain size.
Tolerance: strict tolerance extent control
Grades: various for choice: YG6, YG10, YG15, YG20C, etc.
Physical performance: high hardness and impact toughness, very good mechanical & chemical stability.
Cost-effective
Carbide (either tungsten or titanium) is much better at dissipating heat than steel. Thus, when using these tools, you don’t have to stop as often to allow the machinery to cool off. Also, this dissipation helps the material stay stronger because it doesn’t change the structure of the metal. It has a long service life
Cleaner Cuts and Finishes
One crucial element of a carbide cutting tool is that the edge is going to stay sharper for longer. Because it maintains a sharper edge, that also means that you get a cleaner, neater finish. Whether cutting hardwood or metal, having cleaner results will save you both time and money. Carbide tools don’t damage the grain as much either.
Long Service Life
When you combine the durability of steel with the expert finishing power of carbide, you get a tool that is built to last.
https://www.xymjcarbide.com/products...azed-tips.html
Cost-effective
Long Service Life
