Replace 2006 24VE Carpetting
    Want to replace factory carpeting in my 2006 Tige 24VE. Does anyone have suggestions/recommendations.
    Tige Owner on Table Rock Lake
    Deckadence is what I went with in my 07’ 22VE. Its not the cheapest option but it’s super durable, easily removable to clean, water goes right through it so it dries right away, and it feels good on the feet.
    Im gonna write up a how to in the next few days. It’s not an overly hard project but takes a bit of elbow grease.
      looks good from the top jet.....
      how bad was the old carpet to remove. my old '06 supra it was going to be quite a project.
      2012 22ve.. RIP 4/17
      2014 Z3.. Surf away
        Thanks Sandm! The carpet comes out easy enough it’s the glue that is a b*tch to get out. I used a paint scraper and good old fashioned elbow grease to get the majority of it then I went over the whole deck with a palm sander and 80 grit. Shop vac’d it out and put the flooring on. I’m planning on putting either an epoxy or maybe even gelcoat over the fiberglass this winter but it worked as is pretty good.
          wow. that's what I was afraid of with our old supra. looks good but I'm guessing a few 4-letter words along the way....
          2014 Z3.. Surf away
            Ultradeck's latest post shows a 22ve getting a new floor. It's my goal at some point to do mine.
            https://www.instagram.com/ultradeckflooring/?hl=en
              You may have just changed my mind on flooring, that looks very good. I have seen others using another product made for pool side, looks the same just not sure if it feels the same. Price was around 300 to do the whole floor.
