Winterizing ballast
    Winterizing ballast
    Does anybody have an easy way to winterize the stock ballast system? 2017 Z1.
    I just pour about 1 gallon of RV antifreeze into each bag using the vent hose on the side of the boat. Cycle drain pump on/off a couple times and should be good!
      If we are talking about bags why not just pull them and pour them out? Air Compressor or leaf blower if you didn't have a compressor is otherwise all you need to clear your lines. I always park on a steep hill to empty my hard tanks as much as possible but otherwise leave them as is.
      I do the same thing with my heater. Remove the hoses and push air through them.
