I need to get my 2008 22Ve service before the season gets into full gear. My boat has 160 hours on it, & I am embarassed to admit I have really only had the oil changed. I am trying not to spend a billion dollars, so does anyone have any suggestions on what really needs to be done? My local Tige dealer folded up last fall, so I am kind of on my own & dont want to get raped by the local shop! Thanks for any suggestions.
Recomended service for 160 hrs?
If the oil was changed in the fall, as it's recommended, then you are ok there. Change the trans and V-drive fluid and Impeller. Everything else is just an inspection and address as needed.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
