Boat upgrade and draft measure
    I'm planning to upgrade my RZR to a 23 ZX. The problem is I don't have a lot of water where my boat lift is located so my question is if both boats as the same draft (29``) does it mean that I should be OK with the 23 ZX ? Thanks in advance for your advice.
    I have a 23 RZX and buddy has an RZR. We both keep our boats in lifts with 36" of depth and make it. Ill say since the bigger boat takes more to weight down, it isn't as sensitive to crew size. Keep in mind that RZR may have a 13"-15" prop on it, where the 23 ZX is going to have a 16.5-17" prop. Hope this helps, but I've found the 29" to be accurate, and depending on crew size, you may be better off in the 23, as its not as weight sensitive. Cheers!
    -Brandon Lucas
    Houston, Tx
      Thanks for the reply !
