So I have posted three times on this issue. So here is a recap of what happened in case someone else has it happen to them. Turned on blower and after a few minutes went to start no click no noise just silence. Checked to make sure it was in neutral and safety lanyard was in place but then realized no blower. Checked battery and it was charged. Checked cable lines no power from switch going out. So I thought bad switch but when I pulled out switch it had a 200 amp fuse that was blown, Changed switch and fuse it blew again so I assumed and prayed it was starter. Took starter out had it checked and thank god is was shot! Put it all back together and so far its running fine. So things to know is there is a fuse on the switch post but its 200 amps and its not easy to get to on the water and if it goes it has to be a significant issue. the bad starter did not blow any other fuses but the switch fuse. Hope that helps other newbies.
2013 R20 would not start resolution- Interesting diagnosis and symptoms bad starter
