‘06 22ve with pcm 330
Wife was out with some friends last weekend and it died and won’t start now. Rolls over and tries to start, stumbles a little after I let off the ignition like it’s trying.
Seems to be an ignition issue. Won’t fire with starter fluid. Fuel pressure is good. Changed cap, rotor, pickup module in distributor, plug wires. Still nothing.
Pulled plug wires and checked fire. Little to no spark at plug wires. Weak, orange spark at coil wire. So from everything I’ve been reading and everything I’ve checked I thought it had to be coil or ignition module. Changed both and still same symptoms.
I’ve checked compression. Batteries are charged. 2 batteries on #1 switch. 1 battery on #2. I’ve tried starting on each battery switch setting. Hard wired the kill switch.
$400 in on this go-around, any ideas before I drop off at the shop?
