Minor Prop Damage - consider replacement?
    When to consider replaci got prop, with minor damage but no vibration or performance degradation?
    late response but yes pull it and get it repaired, consider getting a new one and use the repaired prop for back up.
      You absolutely need to get that repaired or replaced. Even minor damage will create vibration in the driveshaft and can permanently damage your vdrive and/or transmission.
        You need to get it repaired as driving with it like that will definitely do damage to your prop shaft seals and transmission
        Pull it off and once its repaired it will be as good as new
