Has anyone figured out a way to keep the bimini on the Alpha Z tower up when the bimini is closed without scratching the !@#$ out of the tower?? Thanks.
2010 bimini
we use 4 bungee cords. 2 in the center section.
the other 2 at the outer ends to seal the bimini boot. we had a screw come loose on the bimini support pole come loose and got to the lake and found we were missing a front bimini pole??? Got home and it was laying in the grass near the driveway, lucky... now using some loctite on those screws.
