How do you remove the rear center section for easy access to the V Drive? It is not obvious.
08 RZ2 Rear Seat
The easiest way is to have someone crawl in the locker and hold the nut, while the other person reaches through the access port in the seat to unscrew the bolt. The ones in the carpeted strip like freeheel4life is describing are a real PITA.If I'm not surfing, I'm making money to surf.
Tigé Junkie
- May 2013
- 920
- Central MN
Originally posted by JWehrheim View PostHow do you remove the rear center section for easy access to the V Drive? It is not obvious."I think I am pretty smart for an idiot"
