o great..........
TAPS fried
@ Jason B - I walk up to the parts counter and ask for a replacement relay and calming state - and I have brought my own KY.
Update from me - I thought I had the hydraulic, but when I crawled down their it's a Lenco Electric. So I followed the advice of Whitlock87 - I couldn't undo the pin where the ram attached to the plate, so I just unscrewed the plate and ram connection. The ram spins - not easily, but it can be done by hand. I think the ram has like 2" or so of travel and I'd like to get it at 1/2 way - so I spun it 8,734,122 revolutionsor at least close to that many.
I wish I had a better way to judge the ram travel than eyeball'ing it.Buy my kid's board! http://www.flyboywakesurf.com
Well this changes everything. You will have coming out of the black box a Yellow, red ,and orange wire I think. There will also be a black which goes to ground. You will also have your smaller gauge wires coming from your throttle handle switch. I would assume your red larger gauge wire will be your common or power back to your ram or jack. yellow and orange will be for up and down. I could be wrong on the color combo or yours could be different but those 3 will run you Taps. Right under the dash you should see a buss bar that will have 12 VDC on to jump from.
