I am installing a Blue Sea Switch in my boat (1995 SLM Comp), it does not have a switch currently. Eventually I will add a second deep cycle battery so the switch does have the option for a second one, but not this weekend.
The question I have is what gauge wire I should use from the switch to the battery? The wire coming from the motor/alt is 2/0 Ga. and I have two amps that peak at 250 watts & 500 watts both running 4 Ga. wire. Do I need to run 2/0 Ga. wire from the switch to battery #1 (and eventually battery #2)? Or can it be something smaller? I'm assuming I need to use the same gauge wire for the neg (battery 1 to 2)...?
Sorry for the silly question, I just want to do it correctly the first time.
