So i just moved to a new lake home. I installed the cradle, but will have to lower the tower due to dock roof height. I installed the cover, but extremely tight.....i assume it goes over the windshield and under the tower? Any help is appreciated......alpha e2 tower, first time to actually use the lowering feature
Rzx2 cover with tower down?
I have the Z1 and I had to change some of the location of my lift so I could leave the tower up when I bring in the dock. But I use to have to drop the tower down before I had the lift moved.
The cover still goes over the windshield but you wont be able to put the tower completely down. I would start with putting tower down 8 inches or so above windshield then put cover on, pull the cover over the windshield and as I worked towards the back I would drop the tower until it started to touch the cover, turn off batteries and you can still velcro around where the tower legs are. Then I could lift the boat the rest of the way up. Sorry I dont have any photos, but was relatively easy to do.
