I need to replace my bilge pump and can't find the pump please help it's a 22ve thanks
Help with bilge pump
Originally posted by Timmy! View PostIt should be at the back of the boat on the bottom in the center, near the drain plug.
Check to see if you also have some carpet fibers blocking the strainer also. That might be your issue.
Are you heading out to Camp Far West this weekend? Saturday?
Originally posted by da.bell View PostDid you take the screen off and clear out the carpet fibers? The pump could have gone bad like you are pointing out.
Yes, we will be there around 10 AM in my RZ.
You have to remove the rear panel to where the battery(s) and access to the engine would be in the lockers. You can't just go straight down from the top of the engine.
One reason why I made sure that I can get into my back area with the RZ before I bought it.
$300???? he is nuts. The pump is $50 (appx) so his labor would be $250???? What is that dude smoking?????
Larry, I had mine clogged with carpet fibers too. Light would come on but nothing would happen. I could reach it from the engine compartment, but I'm 6'6" so I have longer arms than most. I think we have almost the same boat. I wish I was going to Camp Far West this weekend but my wife is on bed rest until next week with our baby on the way.Attached Files
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by Ptown View PostLarry, I had mine clogged with carpet fibers too. Light would come on but nothing would happen. I could reach it from the engine compartment, but I'm 6'6" so I have longer arms than most. I think we have almost the same boat. I wish I was going to Camp Far West this weekend but my wife is on bed rest until next week with our baby on the way.
Just a reminder for all to check their bilge pumps this spring. I would have noticed it immediately once I saw water shooting out the side from the bilge pump and it would have been a mistake with no cost. So bilge pump failure has become a sensitive issue for me.
After cleaning, the pump was still bad, so I suspect the gunk had blocked the motor, then the motor burned up. A new one is working good so far.Be excellent to one another.
